Steve@Advance
Working on a Gravely home duty ZTR. Trying to find a replacement axle for the left Hydro Gear. The gear assembly is part # 00177300.
I'm not finding a parts break down from Gravely. I do find an upgrade kit for a Toro, part # 115-5039. The parts look right, but not finding any dimensions to compare.
Any ideas? Think this will work before I order it?
Also, what oil does this use? It appears to be heavy gear oil, 90 or 140 weight? It appeared to be filled nearly to the top, is this correct?
Thanks!
Thanks!
