cub cadet 1054 ?
54 in cut -26 hp Kohler Courage, hydro-396 hrs 2010 model- has new belts good blades. Was traded for a o-turn due these tractors have a good track record? pro-con- will be mowing about 2a mostly level.
thanks.
Have exactly same model,(2009). Have just under 300 hrs.
Have replaced belts, blades and battery. Do oil, filter every
50 hrs and air filter clean. Has grease fittings on blade
spindles. Hasn't needed any other work, still operates as
when new.
