whizkidkyus
- Location
- South Central , Ky.
Hi ,
I have a neighbors John Deere model 314 to work on . ( See post below ) It has a model K321AQS engine on it !! It says that it doesn't run right . Says that it's in the carb . Carb has been cleaned and rebuilt before but it still does it later ! It has points in it and a friend ( who also works on engines ) also said the it could be in the firing ! Battery will only spin starter but not engage engine, like a stuck solenoid ! Does it even if I boost / jump start it ! Where's the solenoid at on these starters ? What's the adjustments for this carb ? Is it hard to rebuild ? Any tricks / techniques ( special ) ? Special tools ? Anything to look for ? I haven't heard motor run yet because of starter ! I have an idea as to what could be wrong or at least part of the problem - vent hole is open in gas cap . Just a hole there to let rain come right in . Any and all help appreciated . Thanks !!!
Whizkid
Whizkid
