Thought I would check the points and go from there ...
Will at least some of the problem is solved .... the points gap was waaaaaay over , might of been 30 or bigger .. so I shut it down to 20 .. the fuel pump is leaking , so I got a new one coming ...{ suppose to be here Friday } then I will try and set the carb. ... I had it running at a little faster then idle and ran good no backfiring ... at least for the short time I let it run { it's in my shop and cold outside so didn't want to get to much exhaust fumes }
Anyway just wanted to let those that gave advice THANK YOU ... mark
