Craftsman t3200
Have Craftsman T3200. Always ran pretty much perfect as long as I keep the oil good and the air filter clean. Just started blasting white smoke 2 day ago when I went to start it up. Stored in a shed. No Idea were to start. One plug was dry and one plug was half wet like it got oil splashed on it. Oil is at the fill mark. Idea's or suggestions? Never worked on anything this new before. We bought it new, and I suppose some warranty may apply, but figured I'd check here first.
usually white smoke is gas in oil. double check your oil level or better yet drain it see what you get. if you think it has warranty you better not touch it or warranty will be void!!!!!!! in this shop under warranty and you touch it its all on you period!!!
