I got a MF8 hydro. The tractor has set outside for a long time. The Tecumseh had a hole in the block.
Now I installed a Briiggs 8HP, the tractorwould not move with its own power. It rolls freely, the cable and the lever under the tranny moves as I move the F&R lever.
The lever to desengage the hydro under the seat was stuck, but I unfreezed it.
Is it possible that the lever is in engaged position, but the system is still disengagd inside? Is there an opening to see something?
Any hint on what might be the root cause?
