I have one magnet that has come dislodged from the inside of the fly wheel from a Kohler Magnum 20 engine. There are a total of six magnets. It has been suggested to use JB Weld to re glue it to the flywheel.
I do not know which direction the magnet was when removed,top or bottom???? Does it matter in this case? If you refer to my pic. of the flywheel, I am assuming the magnetic poles are 180 degrees opposite. Three magnets with red tape on flywheel. Three magnets that are blue tape. Can someone explain to me if this assumption is correct?
Thanks
Thanks
