Kohler K321 carb.
Dutchman
On my case 444 it has a carb. with the wrong CHOKE shaft ... been looking on e-bay and notice
that most the carb's come with 2 choke shafts ....
QUESTION ... where can I get the right shaft for me ....
THANKS for any help or advice you share .................. mark
Model and spec. of engine and a picture of the carburetor you have would sure help.
What parts Kohler still has for those K-series are very expensive.
Hi Dutchman, your carb must be an aftermarket carb and not all come with 2 choke shafts, I have installed a few of those carb and they are good what I did and a couple was to use the old shaft from the worn out carb but on my last one I carefully ground off the end of the shaft removed the bellcrack turned it 180 degrees and riveter it back and its working good.
GB in MN
