Case 444 key switch
Dutchman
Can anyone tell me where I can get a 4 position KEY switch { off-lites-run-start } I have try getting one from e-bay .. but it DOESN'T work ... when I turn it to START , I have NO HOT terminal to the coil.. the spade goes dead in the start section ... everything else works ... But I NEED the RIGHT switch ...
THANKS for any HELP .............. mark
Use the link below and then provide Bob with the model and PIN of your tractor to make sure he sells you the correct switch. You can buy it with a credit card and Bob will put it in the mail for you the next day.
Online parts store
THANK YOU , Tom ...... I was hopping someone still have them ... can't believe I'm the only one with a switch problem .....
Will be calling tomorrow ..
THANKS again ............. mark
You are far from being the only one in need of one of these switches. They are a routine maintenance item and many weird problems can stem from a faulty one.
