David Bradley
p schacht
Working on cutter bar Model # 91757569 trying to buy clutch bearing part #4666m thrust bearing and 2 clutch facing part # 4318m anybody know where I can buy these parts thanks Paul
Any reputable bearing supply store should be able to match them by either the numbers on the old one or if no numbers they can measure them and match up the dimensions. Most bearings are measured in millimeters except for some special ones that are measured by the inch system. Be sure they use calipers instead of a measuring tape for dimensions.
