Source for power take-off u joints/drive shaft
Jack345
My Ariens S16 power take-off u joints are bad & need to replace. The drive shaft is spline female to u-joint, approx 1"square drive shaft to square female slide, to u joint to splined female. Overall about 12". Its for the front pto to drive snowblower. I'm sure a machine shop can make one up but think they may be available from another source made up. Thanks
Also look into a [ Bearing and Gear Sales ] joint. They will not be cheep but they know how to find stuff.
I needed a new driveshaft for my Ford LGT-18H because the u-joints were not serviceable. A complete driveshaft was available from New Holland for over $400. I went to Tractor Supply and was able to pick up everything I needed including u-joints male and female sliding components for around a hundred bucks. ' had to do some welding but now I have a driveshaft better than original as it has grease fittings.
