Solid state regulator for Cub Cadet ?
Dalex
I have two 123's and neither one charges .Both crank just fine . Is there a solid state reg. for these gen-starters ? Or some alternate method like a fixed resistor ? I don't want to waste money on Chinese regs....
Dalex Cub regulators are mounted on rubber strips there is a ground wire from base to reg if this brade wire is loose or broken it will rot charge
traper
