I just got this machine, serial number crosses to being built in June of '72, have a problem with it.
When I got it home and tried to start it, pedal locked down, and in Neutral, it wanted to lurch forward while cranking. It was bad enough so as to "fight" the starter/gen, I wound up having to pull the driveshaft at which time the engine started right up... It has the manual relief valves and they appear to be free/neither is stuck. When I got it the tunnel cover was off and in a box, as the flapper to depress those pins was broke. which brings up another question; I got a replacement flapper, and there is no spring pressure to hold them down to push/tow. I have to hold the lever to hold the relief valves in a released position. Is this right?
