Briggs parts needed
Tom RS
Looking for a fan shroud and a pulley for this motor.
Its a 23 FBC, about 1950 vintage.
The pulley has a major chip out of it and the shroud is rusting away.
Is that engine on a Shaw, or is it homebuilt? The cover would be Briggs oem. But the pulley is probably either owner added or from the tractor manufacturer.
Some of the Shaws I have seen had a pulley with a notch in it on the crankshaft to improvise a rope start pulley. You start the knot of the rope in the notch and then wind the rope around the pulley.
Its on a Shaw R8.
And yes I think the pulley had the notch where the piece is missing. The tractor had a generator that was powered from this pulley also.
The pulley is aluminum but steel would also work.
There's one on E-bay right now for $20.00.That drive pulley would be a hdwe/lawn & garden/small engine shop item.
I love it when people post a question,you try to answer them,and four(4) days later they haven't either checked back or acknowledged the answer!!!!!!!!!!!!!!!!!!!!!! Same thing for the AC B-10 post above.
I checked on e-bay and couldn't find this.
I did find some complete motors though.
Thanks for your reply. I appreciate it.
It's still there(sun morn)Go thru e-bay to lawn mower part & accesories Type in briggs stratton model23 engine shrould
Seller is clintonpower
OK - found it.
Too its a bit newer style than mine. Doesn't have the center louver area. But I may just go for it anyway.
Thanks
