jim_uny
have honda gx 390 with metric drain plug in base. want to extend it 2" so oil does not slobber everywhere. where can i get metric threaded pipe with cap
Try the link below. All you really need is an adapter fitting that will take you from the metric hole in the Honda to 1/4 inch NPT so you can easily find the length of pipe along with whatever additional fittings you need.
H & F
Since everyone else has the same problem it has been made easy for us. I have these on most of my Hondas (see the link). costs a bit of money but so does one fitting from a hydraulic supply house.
Honda GX390 drain hose.
I went to O'Reilly's and had them make up a small-diameter 6" long flexible hydraulic hose, with fitting on one end and I added a drain valve on the other end. When I get back around to it and get it screwed in I think it will solve all those problems.
that type setup goes on every new unit before goes out the door,make the length as needed per mower. i always use hose (no long pipes for drains,those can cause issues also.)
