Kubota G6200
GLMPA
I have a Kubota G6200 diesel that has new fuel injectors and glow plugs but I cant get engine to start. Any thoughts? Compression issue or fuel pump? Thanks
I guess you have bled the injection system by the manual.
Does it use a shutdown solenoid? If it uses an energize to run solenoid, you may have a broken electrical connection or blown fuse.
Are you getting smoke out the exhaust when trying to start? You should be, either white which is unburned fuel or black partially burned. White may be due to low compression, need to test to be sure.
No smoke means no fuel. Bleed procedure?? shutoff valve/solenoid? filter? Just start from the tank one step at a time until you find the reason.
I inherited a Kubota diesel that also wouldn't start. It had a pull-to-shutoff cable. Unlike my Ford the cable pulls the lever on the fuel distributor but does not push it back. The lever is supposed to return by spring pressure and was hung up in the off position. Freed up the lever and everything was fine after that.
