Hello, I normally hang out on the CaseDB forum here on the YT site, need some Kohler specific info as it pertains to a 222 Case Hydraulic drive lawn tractor.
Finishing up mowing Saturday and the K321 blew a six inch hole in the LH side of the block, still running at that point and blowing oil all over , had to shut it off with the switch, would probably restart but the starter is hanging on the cable and resting on the motor mount.
My question simply is, is the Kohler K 321 AS specific to Case as there is the Hydraulic pump pilot and bolt pattern on the PTO end or are all that series so equipped, also what is the shaft size of the PTO end of the crank on a 222 where the Lovejoy fits the crank.
Is the narrow pan engine the same height as the wide mount pan as I could redrill the mounting plate for the wide mount engine if all else matches.
Thanks in advance,
Mel
Thanks in advance,
Mel
