opinions on a case/ih 1120
deene
have just got one and its not running yet but they were only made one yr according to tractor data..anyone have any info on them good or bad.. parts available?...thanks
If you have looked at Tractor Data dot com, then you must already know that CASE did not make that tractor. They partnered with Mitsubishi to re-badge one of their existing tractor models to be sold as a CASE sub-CUT in North America and possibly elsewhere. Mitsubishi makes excellent quality products so I would not be concerned about owning one. As for parts, your local CASE/IH dealer should be able to advise you whether that model is still fully supported by them or not. Mitsubishi would also be another source for parts because they likely put out a nearly identical tractor with their name on it.
