Battery disconnect
redtom
Does anyone make a battery disconnect switch designed fro the "bolt" style lawn tractor batteries? This is on my uncles zero turn which sits for 2 weeks at a time and I would feel better if it were disconnected. I really don't want to drill any holes for a panel mounted switch so I was hoping for one that can mount right on the batt terminal like the regular top post batts.
I have a top post dis connect on my battery. Take the bolt out and it should just about slide right over the lug. On the cable end mine has a hole in it so find a bolt and you should be set.
The military has used them for years. Hal
I have a battery disconnect that is bolted into ground. It has a key that turns it off and on and can be removed to kept somebody messing with tractor.
you can get these at Napa or any threshing show flea market has a bushel of them.
