help with my 444
Dutchman
As some know I got a Case 444 garden tractor in pc's .. been painting it and now putting it together ... that's the fun part since I didn't take it apart ... put something on , only to relies that I had to put another pc. on 1st ,, so take it off and try again ...
Now my QUESTION ... trying to put the hold valve on .. I got it hook up to the hyd. motor.. but now I can't get the lines hook up to the valve ..... Do you have to take the valve out and hook the lines up and then put the valve back in place ?? or is there some other way ??
THANKS for your help ........... mark
Mark, Leave the bolts loose till the lines are hooked up hand tight then snug your bolts and then finish the hyd. lines. Does your have a holding valve or jus he travel control/deck and three point valve. HTH Tom
