Re: help with my 444
Tom Arnold
09-10-2015 18:48:47
All holding valves are connected directly to the drive motor but there were several different holding valve kits available that were based upon the model and year of the tractor. What is different between the kits are the two steel lines that connect the ports on the holding valve to the ports on the Travel/Lift valve. If your lines do not meet up with the ports at both ends, then in my opinion, you have the wrong lines.
Fortunately, CPD has begun to have fresh stock made up because Eastman refused to do it and simply made those part number NLA (no longer available). If you have the correct lines, then loosening off the fitting that joins the holding valve directly to the one motor port along with the other pre-bent steel line should give you all the slack needed to get the fittings on the other two lines to thread onto the respective ports.
If that cannot be done, then I suggest that you use the link below and contact Bob Meyer with the PIN and model of your tractor so he can quote you on the correct lines.
