Case 155 parts availability
OL1800
I'm looking at buying a case 155, it would need a gas tank,steering wheel and a seat. To make it correct. Does anyone know of any for sale. And also does anyone reproduce the rings for around the headlights. Any help would be appreciated. Thanks, Randy
Used parts can sometimes be found on e-bay. Do a search under "case lawn mower". Reproduction parts such as the hood, side panels, seat pan, seat cushions, decals and steering wheel are available from sources such as Maple Hunter Decals and Steve Guider in Ohio. The gas tank is not being reproduced unfortunately and I am not sure about the headlamp rings.
You could contact Bob at the link below to see what items are still available from Ingersoll these days.
case garden tractor parts
The headlight rings are the same as the ones used on the hundred and thirty series full size case tractors, so they are out there. Go to the big tractor forum above and send a message to John Saeli. He is a dealer and should be able to help you out on those bezels.
