Had to replace the ignition switch due to a burn out. I thought I had all the wires correctly put back on but I lost the electric to the tractor when in the middle position on the switch. When I turn all the way to the right the started engages and turns the motor over. When I leave off the starter position I have no power to the rest of the tractor. I had installed an electric full pump years ago and ever since I installed the new ignition switch it stopped pumping. Checked it and still works when hot wired. At wits end trying to figure out the ignition switch. All help welcome.
