Jacobsen Chief 1200 pulley 218013
john_eb
New User
I am still in need of the driven pulley for a Jacobsen Chief 1200 P/N 218013. If anyone has one to spare please let me know. P/N 218014 is a double pulley, it is not necessary for my application, but will work.
I have a Chief 1000 gear drive for parts. I'm not exactly shure which pulley you are referring to since I do not have a parts book. Is it on the engine or transmission? If yours is a gear drive I think I would have the transmission pulley or engine pulley.
ChrisQ,
Do you have a deck for parts? If so I have a 1966 Ford 80 and I am in need of a set of blades and all the hardware that holds them on. Any chance these are the same? I believe your model is the same tractor except with a 10hp engine instead of the 8hp I have.
Gary
It is the pulley that is driven by the engine located on the reversing gearbox that drives the transmission. It is the pulley that sits over the gearbox.
John, my email should be open. Yes I should have the pulley that goes over the reversing gearbox. If I remember correct it is a 3 spoke pulley. Email me and I can get you pictures of it.
Gary, I do have some deck parts. Is yours the 3 blade aluminum deck, or the steel 2 blade with a timing belt? I have parts from both of those. My email should be open.
(quoted from post at 19:08:47 08/17/15) John, my email should be open. Yes I should have the pulley that goes over the reversing gearbox. If I remember correct it is a 3 spoke pulley. Email me and I can get you pictures of it.
I don't see any way to e-mail you, my e-mail is [email protected]
