Dave Sherburne, NY
I am in the process of changing all the fluids on my latest purchase, a Case 444. I do have an owners manual which says 3 pt.s in the engine, doesn't look like much in there. The differential says 3 qts. I drained all the water and oil out of it and it doesn't seem to want the third quart.maybe there is another fill hole I don't know about. I am filling it thru the hole just above the hitch. I could get 3 quarts in by raising the rear end, but I doubt if it was designed that way. Nothing in the manual says how much goes in the hydraulic system. It says to keep the level 5 to 6 inches below the fill hole so it doesn't overflow. Are these capacities correct?
Ser.no.is 14039621
Ser.no.is 14039621
