Tecumseh flywheel
Mark-Ia
Looking for a flywheel for a H70 motor. Model# H70-130076 ser.#0076-16063. A part number would be great if someone could tell me what it would be. Electric start with charging magnets. The magnets are coming loose. Thanks...
According to microfiche card I have the H70 eng with elect start/alt used 3 different pn flywheels depending on magneto coil pn(6)& pn of stator plate(2)
As has been said goto jacks small eng or partstree & check assembly drawings/parts list for your mod/spec# eng & try to determine which coil/stator assemby you have to get correct pn for flywheel.Check eng,pn for mag coil/stator plate may/may not be marked on each.
The best repair is to replace the flywheel, but, If all else fails, and the magnets are undamaged, they have been glued back on there with epoxy.
