Simplicity 5216 carb gizmo and hydro
Tom R S
Just plcked up a nice well maintained tractor.
On the carb there is a cylinder the size of a condensor with one wire connected.
What is this.
ALSO the tractor creeps forward when the hydro lever is in the neutral position. What is the best way to adjust this?
That is the fuel shut off solenoid. It will click when you turn the key on and again when you shut it off. The creeping may just be an adjustment, but look the linkage over for worn parts.
