Now I can post a little tail. My cub cadet 1330 tractor that I use as a motor tug started right up. Went through the back yard and a little further and then the trouble started. Started to slow down and buck. Had to pull out the choke. Then almost full choke. Just got it back to the yard and figgered it was time to check the carb. Took air filter box off and un hooked the gas hose and carb control linkage. Took bowl off of the carb, checked float and valve.
Now do you guys know where this is going? I have a gas can that has a tinny bit of rust in it. I fergotttt to run the gas in that can through a filter paper. CHANGE the little throw away fuel filter before you start silly! Runs like a top again.
