JD 165 hydro transmission is dieing
SDE
This morning I removed the filler cap and noticed that the expansion tube has a split in it. This would allow the fluid to come out of the vent. Would this create enough of a problem, that it will not drive like it should?
Coasting down hills and then hesitating to move as it should?
Thank you
SDE
My first question is: Do you see any leaks? My first thought was low on fluid. I contacted one of the hydro mfgrs. once with a problem and they said they use 10w-30 full syn oil in theirs if you are curious as to what you use for fluid.
