Speedex M 14
MoMac
I need to replace the front tires on my Speedex M 14. Looks like you must unbolt the wheel halves in order to get them off the axel. Can't see a snap ring or clip on the inner hub. Thanks, Mike
Not faimilar with the Spedex, A Picture of the wheel would sure help, but some of the smaller wheels are indeed three pice rims. You had to take the nuts off, remove the hub and then separate the halves of the rim.
BE CAREFUL!!!! Let all the air out of the tire before attempting a tire repair on these wheels!!!
