standard twins
Those tractors were ahead of the times and had all gear drive, multidisc clutch that ran in oil. They would pull
the 10-inch plow easily. Hal
I bought a Viking G in 1960. They used an 8-inch plow on it and when I sold the tractor in 1971 I kept the plow and installed on my Wards tractor. I still have the plow. Hal
I had a hard time figuring out getting the plow to work on my Wards tractor. I ended up making this frame which
I had to make a template of the handle bars so I could heat and bend them. Then it would plow. I drilled and tapped the sleeve hitch using 3/8 cap screws, but that was a pain to install and remove. I finally had a bracket made that would just slip over the sleeve hitch using one pin. You can see that in the pictures. There was a drawbar made and welded for the depth control lever on the frame too. Hal
