LT155 hydro leaking, any fixing
matthies
My hydro starting leaking out of the forward/reverse shaft on top of the transmission. Jdparts doesn't show any breakdown to replace oring/seal. Case says something like TUFF TORQUE and a jd part number. Seen a used one on craigslist for $200. chris
Order me one too, my JD275 is leaking form the top shift lever when you fill it with hyd fluid. Mine holds 5 qts. The leak slows when you lose about one qt. I think I'll wait to winter to fix mine. Now, I park it over a dirt pile in pole barn and let it leak on the dirt.
