JD 300 LGT power steering instructions
Roger in Iowa
Anyone have the instructions or parts list for adding power steering to a JD 300 LGT. There once was a kit to do this but no parts list on line that I can find.
Basically, you tap the steering valve into the output of the hydro charge pump, ahead of the implement lift valve, and the return from the steering valve continues on to the implement valve.
Or you could just buy my 318. Dirty tank and has the loping idle thing,this week 550.00
The kit was made by Brantley, and it worked with their loader for the 300, 314, 316 Kohler, and 317. Mainly for the 317, FWIW.
Steve I a north of Hannibal. It will run on a shot off starting fluid,but I know the gas is bad, and if I fix it it will be for sale at 1200.00. Call me, I am headed for Sedalia in the AM. 217/four three zero/zero 829.
