cub cadet 1000
obradovich08:
There are several mower decks that could be used on the model 1000. What model of mower deck do you have...???
After you figure out what size you need I wouldn't go to NAPA for that belt unless they are selling you a Stens brand. I've tried using off the shelf "mower" belts on the mule drive and they last less than 8 hours - some less than hour. Cub Cadet/IH sourced belts or Stens are the only ones that will give you any kind of life. You can get away with generic brands on the deck itself, but the mule drive belt is a special animal.
This will give you an idea of what you need to know to order the belt - deck size and model:
http://ccspecialties.org/belts.html
Obradovich08
The correct belt would be.... [b:df706918e3]IH-490489-R2[/b:df706918e3] Mule Drive Belt
