Anonymous-0
I have a john deere gx345 mower that is 4 years old. I have had problems from the get go with this thing running. The first year the dealer picked it up and replaced the carb. That lasted a few cuttings. Same thing. Runs for awhile then quits. Won"t restart. Next time it might start. Maybe not. I took it back and was told a mud dobber clogged off the carb vent. It ran fine for awhile. Few weeks ago I put in new plugs. Ran fine until was shut off. Won"t start again. The plugs aren"t showing any fire when out of the engine but, there is voltage to the coil packs on each side. Anyone know if the plugs have to be under compression to fire. I"m leery about taking it back for repair because of the previous results and cost out of my pocket. Seems like it has to be something simple but, can"t put a finger on it. Fuses are good, starter spins fine, new fuel and filter.
