Got a mower for someone and was going to be a nice guy and get it all ready to go. Bought it with the engine full of fuel after the needle/seat stuck. Common issue on these. I fixes the fuel system cleaned the carb (done hundreds), etc.
Engine runs with good noises, power, etc BUT has a terrible stumble at low power but goes away with load. This to me point to the pilot circuit in the carb since when on the main jet, it runs fine.
Well, That carb is CLEAN. As I was examining other things trying to spot the issue, I found an obviously blown head gasket that did not show up on comp test but engine would backfire a bit. I figured we had it! Pulling a little air at low power but would level out with load (more throttle). Well, that did not fix it!
I have my inductive light on the coil wire and I just cannot be sure it is missing or not by the light. I removed the kill wire so that is not causing it.
I honestly cannot be 100% sure if this is ignition or fuel related! I did the simple tests to try to prove a fuel issue and makes no difference! Try to add some choke which would usually make a lean circuit happier. No change other than it tries to kill the engine. I removed the air cleaner which will boost the air, no change. No black smoke. I tried tuning the low speed screw. Engine does not seem to care.
What is VERY puzzling is this is LOAD related, not RPM related. If I rev the engine to full throttle, it will stutter around all the way from idle to WOT, but add some load, the engine starts hitting normally.
Very hard for me to consider the coil here but I swear there were a couple times I could not get a hot restart and there was no fire! Actually, in this condition, I had the plug in the boot laying on the engine and I did nothing but walk away to let it cool. Go back and yep... We have fire again...
All this points to the coil BUT add engine load it it starts working??? nah! I starting thinking things like crankshaft play that would cause the airgap to change but I have danced around from .005-.020" on the gap with no change.
Frustrated!!!!!
Frustrated!!!!!
