Steve in VA
- Location
- Natural Bridge Virginia
OK, so further investigation indicates that the deck spindles are "acceptable" and there is actually minimal turning resistance. It looks more likely that the attachment drive isn't fully working. The linkage has a lot of slop. With tension removed from the deck drive belt, the drive doesn't seem to move well enough to drive the mower. Neither manual I have discusses the drive unit so I'm looking for help. Do I need to remove the exhaust and/or the oil cooler to access the drive? Is it a relatively straight forward overhaul? A source for manuals would help.
Thanks in advance.
Thanks in advance.
