The offset hole in washer type valve retainer striped out on a 6 hp flat head Tecumseh. I don't have a spring compressor but will buy or rent one if nessary. I can push the valve the valve down onto the seat through the spark plug hole. If I wedge the valve on it's seat with a wood dowel,can the new retainer be installed without removing cylinder head? I'm wondering if it's common for these to strip out. After pulling the vent plate off,I raised the valve off it's seat with a screwdriver blade. There isn't a great resistance while pushing valve up and down but each time the valve is lifted off the seat it remains up until a little pressure is applied to head. If the head has to be pulled does it sound like the guide should be reamed? Should the valve and seat be reground and/or lapped?
