31 tiller belt sizes
350 dave
HI all, I have found a 31 tiller with mule drive in good shape, no belts. I plan to mount on a 1970ish 112 that has the rear lift package.
Can somebody tell me the correct belt sizes? I will need both: to the mule drive and then to the tiller.
thanks in advance.
d
Dave, you can look up the tractor and the tiller by model # at www.jdparts.com. It will take a little digging, but you can find the appropriate belts. If size isn't given along with the part #, post the #'s and I will look up the sizes for you, if you don't want to simply get them from DEERE.
Dave
Just checked my book, have a 31 tiller on my 112. Thought I had recorded the numbers.
If you have a NAPA store close by, they should have a genuine paper book with the info you need. Look in the section labeled ATTACHMENTS. It even has pictures to be sure you are looking for the right belt.
HTH
Willie
thanks for the JD site. It does take some digging, wow. BUT I think I found them. Any clue on how a return would work if I go0t the wrong one?
thanks for the input. I will track this down in more detail tonight.
