Jonak
I have a 318 john Deere, Just what does the time delay module do? I have no lights on dash, Oil Pressure or clutch engaged lights. Thanks for your Answers, I appreciate them!!
The time delay is what keeps the motor running when you bounce off of the seat.(seat safety switch)
I Would try taking off the ignition switch plug and clean the spades with any abrasive paper. Usually I shoot some pb blaster after doing that. Also, do the same for the 2 connectors going to the module. Does the machine crank over? There should be 2 fuses on
the left side near the battery.
