JGilchr622a
New User
looking for hydro lines that run from control valve to transmission for a model 149 cub cadet i think its ih part # 548042 r1 i need the pressure line
If you have the old pressure hoses take them to a hydraulic shop that makes hydraulic hoses. Colliflower in our area
will make them while you wait unless they're busy. They will install the correct hose ends. Hal
thanks for the info but hose end fittings are to big wont clear the driveshaft and wont fit in the cowl at the control valve i got hoses that had fittings that were id as near to to original pipe size as possible its possible to go smaller but the id of the fittings is so small i was concerned about restricting flow any ideas would be appreciated
