John deer 317
Just brought a john deer 317 lawn tractor. Not running. Replaced points and condensor. Got 12 volts at the + side of the coil. Have the points set at .020 still have no spark at spark plugs. Replaced spark plug wire copper . Coil. Can the points handle 2 car type coil. It has the KT 17 engine. How do check the Hyd oil in this mower Thanks. For the help. Got a plow and disk 3 point Can this mower pull them. Are they worth any thing. Or scrap iron.
If you connect a test light to the (-) (points) side of the coil and ground and try to start it what does the light do, (off, on steady, or flash)?
A 3-point attachment is available to carry your equipment, and the heavy 'ol Sundstrand hydro is up to the task.
There should be a clear sight tube attached to the hydro filler area at the very back. (#1 in the drawing.) IIRC, oil level should be at the middle of the slot in the frame that the tube is clamped next to.
<img src = "http://jdpc.deere.com/pimages/MP26/MP2647_________UN01JAN94.gif">
Below is a link to the engine shop manual, for more ignition help.
Untitled URL Link
The factory service manual, linked in my reply, specifies 0.20", which may be tweaked a bit to set timing. They state 0.017" to 0.023".
