cub 106 clutch
jeff ohio
New User
i have a cc106 that will only move if i push the clutch almost all the way in. clutch disc & throwout bearing look ok will not move if clutch is engaged any ideas? thanks.
Sounds like you are engaging the brakes when you press the clutch all the way down. You may want to slack the brake adjustment a little and see what happens.
jb9959
Spirol pin at the coupling to trans input shaft is sheared off. Go thru hole in front of the seat with long screwdriver and you may be able to pry coupling to see if it moves or the driveshaft can move if it is the front pin.
