I have an MTD Tractor Model 13AM660F131, serial No. 1D162370386. Had the transaxle apart over the winter and added new grease. Just managed to get everything back together. New drive belts front and rear. This Frankenstein tractor is really starting to get to me. She runs fine in reverse, but if I put here in forward she will run for awhile and then jump out of gear an into neutral. When I try to put her back into gear, it almost sounds like your trying to shift a manual shift car without using the clutch. If I hold it in forward it seems to run okay. I have tried adjusting the shift lever multiple times with no change in what happens. What am I missing? I'm about ready to pull the transaxle again and try switching the the forward and reverse cogs in the transaxle.
