gravely oil pressure
p schacht
Have a gravely Gem 16 twin Briggs has not run for about a year I started it up oil light will not go out I checked oil was fill motor sounds good When I take wire off pressure switch lite goes out is there any way to check pressure switch
Remove & clean could just have some goop in opening , Should be able to bench test switch with air ( low pressure )
Just a little nudge. Those switches work at only a few pounds of pressure. Even low air can blow the little diaphragm. Been there. Wipe it clean and squirt a little cleaner in the hole. You should see a very tiny pin hole in the middle. If is messed up it would be easier to just get a new switch. My$.o2.Jeffcat
