11 hp Briggs wiring
doorman
I had trouble with gas getting in oil. Changed oil and head gasket now have no spark. Three wires on switch, orange to oil pressure switch, white to coil, and black to ground. which wire should I disconnect to eliminate switches? This motor is on a Coleman 5000 power welder. Thanks for any help. don
Can't tell you wire color, but if you take the fan cover off and remove the small wire from the ignition coil you eliminate all the chassis stop switch and safety equipment.
Use your judgement when doing this! You may have to pull the sparkplug wire off to stop it.
