I have a Cub Cadet 2130, shaft drive. Lately, whenever I push the PTO switch down to shut off the blade drive, the PTO stays engaged. If I shut the engine off and start it back up, the PTO stays off until I lift the switch and it engages the blades. Push the switch back down and it does it again, PTO stays on until I turn it off . I swapped the switch with the one on my 2155 and it seems to work fine on it so at least I know the switch is okay. Anything else I need look for? Local CC dealer said I need a new PTO clutch but I am not sure. It does not make strange noises like bad bearings or anything. It does not look like you can take it apart, at least, easily. Thanks
Mike
Mike
