Old Rototiller inc Machine
Travis_B
New User
I just got this tiller but I'm having some trouble finding info like a parts diagram for it. It works pretty well now but needs some tinkering. Obviously its been repowered but it uses a vertical shaft motor and the tag says Porter Cable on it so it must be '59 or '60 vintage I guess. If anyone knows anything more I'd appreciate it. Its got hard rubber tires, two speeds( by changing belt position), and no reverse. Like a Horse, the motor is on slides but it moves front to rear instead of up and down.
[/img]
(quoted from post at 19:01:54 04/06/15) I just got this tiller but I'm having some trouble finding info like a parts diagram for it. It works pretty well now but needs some tinkering. Obviously its been repowered but it uses a vertical shaft motor and the tag says Porter Cable on it so it must be '59 or '60 vintage I guess. If anyone knows anything more I'd appreciate it. Its got hard rubber tires, two speeds( by changing belt position), and no reverse. Like a Horse, the motor is on slides but it moves front to rear instead of up and down.
[/img]
If you are still looking for info, I can help.
