Starter Generator for Amigo
amigomatic
New User
Looking for a starter generator for my Amigo 1400 restoration project.
I need a Delco starter generator that rotates ccw pulley end.
The one that came with it is an cw rotation and cannot be easily changed without a complete rewind, so I think the easy way is to find the correct rotation. would appriciate any help, located in Michigan.
You can probably use a s/g from a cub cadet tractor,most/all s/g used on CC105-169 were ccw rotation.Goto ebay and search ih cub cadet starter generator.
Part# for orig starter is probably delco 1101691
I thought we had this covered in your other thread????
As you were told before, a CCW starter-generator for an older Cub Cadet will do what you want, and there's all sorts of 'em on flea-bay, starting @ $49.99 (with free shipping), with NEW ones for $108.00 and up!
Search for "Cub Cadet Starter Generator".
A Cub Cadet starter/generator CCW rotation will work just fine. eBay is your best and cheapest source.
jb9959
(quoted from post at 19:57:32 03/23/15) Looking for a starter generator for my Amigo 1400 restoration project.
Look in ebay. The units that are rated for 20amps charging have more starting power than the smaller 15 amp units.
