Simplicity 725 help needed
jensen766
New User
I have Simplicity 725, the head gasket is bad. The plate on the motor with the #'s on it is missing. I need help finding the parts or idea on how to figuring out the right #'s.
Thank you for your help
Google Simplicity 725 and it comes up being a 7.25 HP Briggs &
Stratton (guess we know where the model number came from), another
hit is an Ebay listing for a flywheel for a Simplicity 725/Briggs
model 19. I would get a repair manual that explains the model numbers
between that and Google and E-bay listings you should be able to get
close enough with a model number to get your parts. If you're looking
for a Carb kit & head gasket carry the old ones to a good B&S
distributor they can probably figure it out. Another thought just
popped up a lot of the older B&S engines actually had numbers stamped
into the side of the blower housing, usually along the outside edge.
They can be hard to find unless you know where to look for them.
